Can Panasonic record from Sky Prog guide?
Discussion in 'Blu-ray & DVD Players & Recorders' started by ONe111, Apr 3, 2003.
  1. ONe111
    ONe111
    Jan 2, 2003
    14
    3
    +3
    Can any E30 owners tell me if its possible to get the Panny to record by simply placing programmes in my Sky Personal planner?
    I know I can get the digibox to change to the channel when the programme is due to start but it would be great if the recorder could read this signal and automatically record.
    Mike
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    The HS2 can be set up to do this, so I guess the E30 can as well, came with additional instructions on how to do it.
    But bear in mind the EPG is often several minutes out on start and finish times and the need for the E30 to start up and set itself up which takes at least 30 seconds and you are going to end up very frustrated.
    Personally I set the epg to switch to the required channel for the previous program if at all possible and the timer on the recorder with a bit of float.
    As long as you leave the digibox on it will switch over when required and then stay on, on the selected channel until you tell it otherwise.
  3. dabbi
    dabbi
    The VCR scart on the digibox does that but no RBG output :mad: :mad: :mad:
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    I have resorted to using the video out scart anyway for reliability.
    If you set up the unit to accept rgb in and someone touches the tv button on the sky remote, the digibox sends video instead of rgb and you record a blank screen!!!
  5. CARLOS
    CARLOS
    Feb 11, 2001
    6,456
    WEST MIDLANDS
    +1,412
    How did you get this to work, I have tried on mine but have had no success ?
  6. bobbles
    bobbles
    why can you not set the sky digibox to autoview?
  7. CARLOS
    CARLOS
    Feb 11, 2001
    6,456
    WEST MIDLANDS
    +1,412
    Thats how its supposed to work, If you switch the Sky box to autoview it sends a signal down the scart to start the DVD recorder but as yet i haven`t managed to get it working ?
  8. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    The input type has to be correct on the recorder, its one of the odd sounding ones
  9. CARLOS
    CARLOS
    Feb 11, 2001
    6,456
    WEST MIDLANDS
    +1,412
    Yeah its External link 1, I`ve tried but it doesn`t seem to work on mine.
  10. bobbles
    bobbles
    i can not test this as sky+ removed the autoview option
    but yes it is meant to be able to do this
    I know it is a pain in the arse but you can vid+ on Panny then set autoview
  11. dabbi
    dabbi
    Yeah, I learned that when my cat stepped on the remote. :rolleyes:
    But I still want to use RGB. Does anyone know if it would be a software update to send RGB through the VCR scart or is it in hardware?
  12. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    The best solution is probably one of the more advanced red dot removers. This particular one sends the backup command every 30 secs to remove the red dot, and the sky button signal to ensure the unit is on as sometimes a software update leaves it in standby. This would also have the beneficial effect of maintaining the rgb output. About £30 but I have lost the link
  13. CARLOS
    CARLOS
    Feb 11, 2001
    6,456
    WEST MIDLANDS
    +1,412
    Sounds good !
    Good old Google ;)
