can one adjust the colour on PowerDVD
Discussion in 'Desktop & Laptop Computers Forum' started by Gazz, Aug 16, 2002.
  1. Gazz
    Gazz
    Evening all,
    This is probably gonna aound like a real Duh! question, but if, for example, I find the colour a bit vivid on a DVD is there any way of turning the colour intensity up or down with Powerstrip or anything else?
    PS just ordered the RGB-Svid converter from JS - fingers crossed...
    cheers
    Gazz
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    If it's just powerdvd you want to change the colour ect on .
    Go into the powerdvd configuration .Go into the video options press advanced. There you should find a menu entitled colour. there should be options for brightness contrast and saturation ( you need to have a dvd running or they will be grayed out)
    This is how it is in my version of powrdvd xp but i think it should be the same
