Can NTL 150k do Xbox Live?
Discussion in 'Cable TV & Virgin Media TV' started by Sheks, Oct 1, 2003.
  1. Sheks
    Sheks
    Jul 23, 2000
    524
    England, Surrey
    +24
    A friend is getting NTL 150k installed soon, he has an xbox (although that's not the reason to get the connection) and was wondering if Xbox Live can be run over the NTL 150k line.
    So if it works, its a bonus, if not never mind.
    Thanks in advance.
    Colin
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    its only available for 600k or 1mb connections.
    dont think theres any chance of getting it on 150k as the bandwidth wouldnt be big enough to cope.
  3. porker
    porker
    Mar 18, 2002
    263
    Teesside
    +26
    It will work fine so long as he does not host.
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    well, thats shut me up
    :suicide:
  5. Sheks
    Sheks
    Jul 23, 2000
    524
    England, Surrey
    +24
    Thanks for the swift replies.
    Porker are you using 150k?
    If anyone who reads this is using 150k with Xbox Live can post their experiences with regards performance etc it would be appreciated.
    Colin
  6. porker
    porker
    Mar 18, 2002
    263
    Teesside
    +26
    No but my mate is using 150K, it appears to perform no differently from my 500K connection when playing on someone elses server, but forget trying to host. You might be able to host a two player game of Ghost Recon in Solo mode for instance because it doesn't require a lot of data to be uploaded, but probably not a team game and definatley not co-op.
    Porker.
  7. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    I use 150k with xbconnect (mainly Halo) with no problems, although I don't host.
    I believe the connection speed is a bit faster when connected to the stb rather than a bb modem.
  8. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    XBL will just about work on 64k ISDN although you get occasional lag problems so it's not really possible. I have had many perfect games of GR on a 64k line though so 150 should be fine.
