Question Can not Format 4TB Hard Drive
Discussion in 'Computer Software & Operating Systems' started by chaz, Jul 16, 2018.
  1. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    I have a brand new unused Seaate 4TB hard drive but when I try to format it seems not to show up when I try and format it What am i doing wrong please? I used a SATA to USB to try and format it. Please see Photo
  2. Nerox
    Nerox
    Oct 8, 2006
    509
    Basingstoke
    +54
    is it 3.5" drive or 2.5" drive?
    3.5" drives require too much power to be powered from a USB adaptor, 2.5" drives are usually ok
  3. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    Ok thanks, what please do I have to do to get a 3.5 4TB hard drive to be able to format it.
  4. LJx
    LJx
    May 29, 2009
    3,270
    uk
    +451
    You need to power it by the sounds of things, plug it into a power supply or a drive enclosure
  5. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,939
    Norfolk
    +2,549
  6. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    I am formatting the drive to go in my media player if that helps I will look on line to see where I can buy a powerd usb thingy one from. But I still need to use the PC to format it wont I? have not done this before well not a 4TB one anyway By the way Endless I use window 7 if that helps
  7. LJx
    LJx
    May 29, 2009
    3,270
    uk
    +451
    Cant the media player just format it
  8. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
  9. DavidG1
    DavidG1
    Jul 5, 2016
    261
    West Yorkshire
    +41
    Once you get a suitable enclosure, if you want windows to see the full 4TB then you need to format the drive as a GPT partition (not MBR).
  10. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,939
    Norfolk
    +2,549
    If it's showing up in disk management then the adapter is likely fine. It's not clear from your description whether it's the option to format or the disk that's not showing up in disk management.
    Does your media player support 4TB disks if it can't format them?
  11. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    Hi Endless my media player can take up to 8GB the hard drive is not Inititalization so I will have to do it via the PC to initalize disc and chose GPT then chose New simple volume to format it then chose NTFS
  12. DavidG1
    DavidG1
    Jul 5, 2016
    261
    West Yorkshire
    +41
    If you are still having problems most likely the media player does not recognise the GPT partition, I would email the manufacturers for advice on formatting a 4TB hard drive
  13. MarkE19
    MarkE19
    Aug 10, 2002
    17,599
    Rainham Essex
    +2,543
    Searching online I found this - [Solved] Installation 3.5 HDD | Egreat Forum
    It suggests that older USB2.0 HDD adapters have issues formatting a GPT NTFS HDD (ie anything over 2Tb). So it looks like you need a USB3 adapter such as the one you linked to above which looks fine.
    Mark.
  14. jimscreechy
    jimscreechy
    Oct 20, 2008
    83
    +9
    YOu are not being clear, you said first you have a drive but are unable to format it, you also say your endless media player will take a disk up to 8tB.
    Did you first put it in your endless media player and try to format it? Did this fail? or did you first try to format it in windows which also failed.
    There are many things here that could be an issue such as power and/or connection type when you are trying to format it in windows which are confusing the issue. If your media player supports up to 8tb drives then making your media player format the drive when it is new out the box is the best thing to do.
  15. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    Thank You yet again Mark For your help " You are a star" :smashin::thumbsup::clap: I am new to all sort of thing still . God How long does take to learn all this stuff it looks like you have to start at about 3 years old to learn all this :) and even then they will know more than I do:D now! I thought learning Latin at School when I was a kid was bad enough:rotfl:
  16. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    Thank you Jim Ordered on of these https://www.amazon.co.uk/gp/product/B01GIZSC9G/ref=ox_sc_act_title_1?smid=AXZ3JQ1GVFPIF&psc=1
  17. MarkE19
    MarkE19
    Aug 10, 2002
    17,599
    Rainham Essex
    +2,543
    Well I started working in IT in 1986 which was before PC's really existed.
    Although I have been working in IT for far too long (for my own sanity :facepalm: ) I still know far from everything. There is a lot I can do, but far more that I rely on good old Google to help me muddle my way through. Sometimes I think my best IT skill is being able to find a good answer amongst all the rubbish that Google turns up :confused:
    Mark.
  18. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    That is the Secret then Mark :D GOOGLE IT!!;) but you still have your secret weapon IT :eek: so you know what you are looking for.Me I Know NOTHING :( even if I google it cause the answer i would get back would be in a language I would not understand in my Day IT would mean Internal Tribunal at work :( Thanks for help once again Mark as always
  19. Navvie
    Navvie
    Apr 17, 2007
    938
    2
    Fareham
    +335
    The 2TiB limit is a result of 512 byte sectors. The MBR limit is 16TiB for drives with 4096 byte sectors.
    As @EndlessWaves wrote, some USB enclosures didn't (don't?) expose/understand the 4096 byte sectors, so you're stuck with 2TiB limit.
    Having said all that, GPT is a good thing. Unless you need compatibility with something that doesn't understand GPT, use GPT.
  20. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    Thank You Navvie for the advice and help
