Can my standard plasma get hi def with the xbox 360
Discussion in 'Xbox Forums' started by artois, Sep 16, 2005.
  1. artois
    artois
    Jan 17, 2005
    813
    28
    Edinburgh
    +40
    Hi folks, :hiya:
    I have a 42" plasma tv which is not hd ready as far as I am aware.
    It does however have a vga port and says in the manual that the tv supports 1280 x 1024 inputs.
    If I buy the vga cable for the xbox will this allow me to play the games in hi def or will i still be out of luck?
    I have searched the web high and low but cant seem to find a definitive answer on this subject.
    I dont really know much about this so maybe ive got it all wrong but I assume that as my pc is connected to the plasma through the vga and I can get resolutions from 800x600 through to 1280x1024 (I play half life 2 at 1280x1024)
    Will you be able to choose the output from the xbox 360?
    I have noticed that people goin on about 720p on the original xbox. Is there anyway I can set iit to that to try? I can change between pal and ntsc with enigmah but thats all I could see.
    Ive just ordered the vga cabe to go with my new console so any light that can be shown on this subject would be greatly appreciated. :lease:
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,236
    103
    +481
    If you told us which plasma you have we could look up the specifications & then answer your questions.
  3. artois
    artois
    Jan 17, 2005
    813
    28
    Edinburgh
    +40
    My Plasma model is the Tiny Focus 4200 42"
