Can my (old) Android boxes still run Kodi?
Looney14
Hi all
I have 2 Android boxes from circa 2015-16.
One is a MX box - with android version 4.2.2.
Second is a K5 box - with android version 4.4.2
Both were bought off ebay - pre installed with stuff and worked fine. but as i've been away from UK they've not really been "maintained" as such and i need some help!
MOBDRO works on both still - so that was a pleasant surprise.
Kodi is the other thing I would like on them - used to use something called exodus BUT that does not work anymore now.
are the versions of my android box able to handle/install kodi? 4.2.2 and 4.4.2
KODI is now on v18 i think.
any advice is appreciated please :)
bubblegum57
Kodi v17 and later requires Android 5.0 or higher
FReaktab has a version of Kodi that works on earlier android versions
FTMC Jarvis 16.2.31 - FreakTab
For Exodus Genesis etc you need to search.
DO NOT ask about these on the kodi forum.
You might be able to install Libreelec Amlogic - LibreELEC Forum
Looney14
Hi what is Libreelec ?
Thanks I'll try install that older version of KODI as i only have android 4.2.2 box and 4.4.2 box
and will search about the video add ons....
bubblegum57
Libreelec is a Linux version of Kodi. But is purely for kodi.
Don't worry, you don't need to know linux.
You can install to & run from micrsd card or usb.
Once installed, you won't see any difference between Libreelec & kodi
Looney14
ok - im not very tech savy to honest
will stick to kodi
i just wasnt sure if it still worked on older android boxes (4.2.2. and 4.4.2)
that was my main worry- but hopefully it does.....
bubblegum57
Looney14
oh - if exodus or another similar video add on doesnt work then there's no point in me trying to bother installing kodi to be honest..........
i basically want kodi for the video add on...
bubblegum57
you do understand that kodi is not meant for illegal sources?
Elephant Man
Looney14 I will say no, those old boxes cannot play h 265 hevc codec, but first try installing SPMC and see how that works with them.
D
Deleted member 765458
Hi all
You need to forget kodi link scrapping addons and go Android based link scrapping apps
21 Best Free Movie Apps To Stream & Download ( February 2019)
Respect copyright owners
