Can my motherboard flash 360 firmware?
Silva
Heres my system setup:
ASUSTeK Computer INC.
System Model: A7N8X2.0
BIOS Version: Phoenix Technologies, LTD ASUS A7N8X2.0 Deluxe ACPI BIOS Rev 1008
AMD Athlon(tm) XP 2500+
Version: x86 Family 6 Model 10 Stepping 0
Speed: 1829 MHz
It has a SATA onboard chipset 3112, will this be ok?
Silva
From what I understand Onboard chipsets (like the Silicon Image 3112 on the mobo) arent a prob - jus pci sata cards, this true?
Vini
Silva said:
Speed: 1829 MHz
Apparently not. SI3112 is apparently the worst. The only known SoA board to work flawlessly is the NF7-S2G with SATA mapped as IDE.
However, I've just replaced my NF7 with a KT880 SoA board which works fine, probably because it has the lovely VT8237 chipset.
ADENCOOL
You could always get a xecuter kit and reflash, they work with anything, but these only one reson to flash - and thats illegal
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
