Can my camcorder connect to a DVD/HD recorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by ttree sound, Sep 18, 2007.
  1. ttree sound
    ttree sound
    Oct 17, 2004
    367
    +13
    I haver a JVC Everio MG57 which has AV,USB and AV out sockets.
    Is it at all possible to connect this to my Sony HXD 870 so that I can record from the camcorder directly to the hard drive of the sony to allow me to view recorded footage from the Sony's hardrive?
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Sure - use the AV out; either composite video, or S-video (S-video will be better quality).
    The HXD 870 has both composite video and S-video inputs on the front (as well as audio inputs).
    Follow the instructions on your 870 to record from that input.
  3. ttree sound
    ttree sound
    Oct 17, 2004
    367
    +13
    The HXD870 instructions only seem to refer to the DV in (i link) I think this is firewire input?
    I was hoping that there was a way of going from USB out to DV in but thats probably a little optimistic?
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes, the DV input is Firewire. That won't work from your camcorder as it doesn't have DV output. The only way is to use the analogue connections. You can't connect via USB.
  5. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Not optimistic.. near impossible.
    They are different standards. There is a discussion on another thread about the JVC Everio 575 which records to HDD but has firewire out
    You may have missed it
    http://www.avforums.com/forums/showthread.php?t=622320
  6. ttree sound
    ttree sound
    Oct 17, 2004
    367
    +13
    Thanks, senu I have just had a look at that thread.
    Whats the technical reason why the usb on the camcorder couldnt connect to the usb on the hdd recorder?
  7. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Simple version of the answer: Technically it could, but it doesn't.
    USB is a digital connection which can be used for all sorts of applications. On a PC you'll have different software depending on the application; e.g. for a web cam, printer, etc.
    Your DVD recorder isn't a general purpose PC, it will have specific software to support specific functions. From the 870 manual it has one USB port for printing, and another for copying still photos and audio jukebox. It doesn't support (at least not as documented) recording video over the USB connection.
