Can Logitec Harmony one work with PS3
dspit1664
logiciel
dspit1664
My apologies I meant to say
Ps3 Bluetooth adaptor to all Harmony 1 to work against Ps3
thanks seen the light now, must read posts fully not skim read ;)
Is see there is one on let's call it - The Bay Or other
However is that going to be my best bet ?
dspit1664
Perhaps a basic question I can discover by checking google and perhaps another thread but.
Can a Logitech Harmony One control multiple devices of any one type ie 2 or more tv's, 2 or more same devices?
logiciel
It can control up to fifteen devices and it doesn't matter what kind of devices they are.
No apologies are needed about the adapter - here are some offers on it: harmony ps3 adapter | eBay.
brookheather
What scenario are you thinking of? For example if you have two Humax PVRs you can force one of them to have a different control code set so you can control them independently even if they are in the same room.
dspit1664
Thanks all for clarifying my options.
Well I have not gotten to the dizzy heights of having multiple PVRs however was thinking along lines of -
Have multiple tv's un the house
Have PS3 next to tv downstairs and also have a WII
Have old (2000) Bose 123 and Sky +HD
The upstairs have 23" LG LCD and shortly to have Dune HDtv + box
And eventually may have a couple more tv's dotted around.
So I currently want to control all my devices downstairs and at night perhaps take it up stairs to control my Tv and Dune.
I also want to future proof myself and de-clutter the # of remotes I currently have as its starting to get ridiculous.
mkomo
I ordered this adaptor from Superfi on Tuesday for £26.95. They've put them up to £44.95 today!!
logiciel
Yes, you can:), and there are others around the price on the EBay link.
dspit1664
Hi brookheather,
I got it for a steal :) many thanks for all help.
I got my Harmony One today and yes ok its got a European plug (2 pin) but hey others who didn't take adv of this big discount.
Re the plug you mentioned. Do I need to get that particular one or can I just get away with the following example or similar?
Adaptor 3 Pin UK into 2 Pin Plug Euro: Amazon.co.uk: Computers & Accessories
I'm no electrician or plug officianado so if a basic question well :)
logiciel
As its name indicates that's the wrong way round.
Your local store should have the correct adapter, with the UK three pin plug on one side, and sockets on the other to take the two pins of your plug.
dspit1664
So if I already have one aka shaver adaptor plug that would do ?
logiciel
The shaver adapter for UK plugs probably wouldn't be exactly right for the European plug.
esulp
I finally got around to setting mine up last night. You should be aware that it is slower than using the PS3 BD remote...noticeably slower. There's a 1 sec delay I found. Does any one know how to speed it up? I have the inter key delay set to 0.
dspit1664
Thanks your lucky already bought one though it cost me a little more £36 but hope to get it setup tonight if I get the chance.
