Can LCDs be transported flat? The definitive answer?
Discussion in 'LCD & LED LCD TVs Forum' started by Colgate7110, Aug 22, 2005.
Tags:
  1. Colgate7110
    Colgate7110
    Sep 12, 2004
    770
    28
    Glasgow
    +75
    Hi guys,
    We're looking at buying a large flat screen for corporate trade shows and the like given that to hire for 3 days costs £750 and you can buy a 32" Samsung HD LCD (first example that came to mind other than the Panny 500 series) for £800... Obviously when the guys started talking about putting a plasma flat out in the boot, I told them in no uncertain terms that doing so was a very bad thing.
    What about LCDs though? I've scouted the forums and a few people have said the packaging says to keep it upright but I think most electrical items say that really so I'm looking for the definitive answer - can an LCD panel (at least 32") be transported lying flat?
    If we can get a final yay or nay on this, perhaps it would be a good addition to the FAQ?
    Cheers,
    Colin
  2. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    If it's going to be for more than one trade show, then wouldn't be wise to get a custom flite case made for whichever one you buy? A couple hundred quid, and it'll be as safe as houses.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I think it's OK for LCD. Apparently the reason it's not recommended (but by no means fatal) for plasmas is because of the heavy glass.
  4. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    It's absolutely fine provided obviously nothing makes contact with the screen (apart from the flat boot floor)
    It's how I transported mine several miles despite having the packaging, and we chuck little 15s around at work like they are bricks ;)
    And assuming of course that your trade shows are less than a year apart, should have some warranty, can soon make up a story about how it got damaged :)
  5. Colgate7110
    Colgate7110
    Sep 12, 2004
    770
    28
    Glasgow
    +75
    Thanks guys! I'll let the team know in the morning. The idea of the custom flight case sounds good too, even if it just adds that professional touch although after a quick Google, the flight cases look even bigger and heavier than the boxes the screens are sold in which will probably be a deal-breaker when I mention it.
    With a bit of luck, I'll be able to schedule a few "trade shows" in my lounge, kind of around the same time the Xbox 360 launches ;)
    Thanks again,
    Colin
  6. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    Yes, but the boxes the displays come in are meant for limited reusal. With the dispaly in a flite case, you'll not have to worry about anything touching it and it'll always look its best. Small set of wheels on it would make it easy to trundle about, and you thow all your cables in along with it, if you get a spearate compartment fitted.
