DavidCook
- Joined
- Feb 20, 2002
- Messages
- 95
- Reaction score
- 2
- Points
- 39
- Age
- 68
- Location
- South Normanton Derbyshire
After researching and reading lots of info I am thinking of getting two sets of KefQ1, fronts and rears. My problem is the viewing position. The setee and chair have to be pushed tight to the rear wall with the TV opposite. I am currently using the speakers which came with the TV on stands sandwiched between the setee and the wall.They are consequently slightly above head height when seated and only a few inches away from the viewers head, If you can visualise that! Myquestion is will the Kef operate well in that situation or are there other speakers in a similar price bracket that would be better? Secondly would I be better taking them off the stands and wall mounting them higher? Thanks
