mad_matt
If anyone has used a Vogel plasma mount EFW2001 on a LG 42PC1D any chance you can give me some tips.
I'm looking at the instructions, which are only illustrations, no written instructions, and to be honest I'm a little stuck. I can see where the 2 L shaped pieces attach to the plasma, the bit that then mounts to these has two square pieces that slide apart, in the destructions it says these are options 1 and/or 2 but each diagram shows them installed!!
So now I have confused everyone, any one got the number of someone who knows what they are doing?
