Can it be done?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by pcpaz, Jul 1, 2005.
  1. pcpaz
    pcpaz
    I recently purchased a sky box from ebay. It works fine and it came with a viewing which was a bonus as I just want to view free to air channels.
    Unfortunately I don't know the PIN on the card and nor does the previous owner and it's not the default one either. Is there a way of reset the pin by doing a full system reset. Phoning sky is not an option as I am not the original account holder on the card .
    Alernatively is there a way of hiding certain channels as my main need for a pin is to have parental control.
    thanks
  2. 9761
    9761
    May 16, 2005
    536
    Pin is usally the last 4 digits on the card?
  3. Bluevanman
    Bluevanman
    Buy a new freeview card from Sky, and then set the PIN to whatever you want.
