nina333
I put my new Iphone 13pro without case on a plastic lamp with wireless charger and while trying to find the wireless spot I was moving the phone front and back many times and realized the cameras are touching and rubbing against the plastic. Is it possible to scratch it this way? And how to properly check and find out if there is no scratch? Are all scratches easily visible to normal eye? Thanks!View attachment 1625327
