can interconnect leads be used as component ??
Discussion in 'Cables & Switches' started by laurence harvey, Oct 10, 2004.
  1. laurence harvey
    laurence harvey
    hi, have three progigold interconnect cables left over, can i use them for component for my viera from dvd player on temp basis please. :rolleyes:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    It won't harm anything
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,392
    Rainham Essex
    +2,451
    As Ian J said it will work but you wont be getting the best from your system. But at least you will have a picture until you can get some proper component leads.
    Mark.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Video interconnects are 75 Ohm, audio interconnects are 50 Ohm. You can use the latter but as already advised you may want to consider changing them later.
    The only difference between a YUV cable and 3x video interconnect is the color of the connectors.
