Can I View Freeview (Not FreeSat) Channels With a Sky Digibox?
Discussion in 'Sky Digital TV Forum' started by Tyler Durden, Jul 25, 2005.
  1. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,364
    Shrewsbury, UK
    +300
    Hi there,
    I just cancelled my Sky subscription when I discovered E4 was available on freeview. I thought I would be able to view all Freeview channels using my Sky Digibox. Now that the cancellation has taken effect I discover that I cannot recieve E4. I gave Sky a call and I have been told that I can only recieve FreeSat which does not include E4.
    Is there a way for me to recieve Freeview channels using my digibox?
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,267
    Manchester
    +757
    E4 is indeed encrypted via the $ky satellite medium.
    What you have is Freesat , not Freeview.
    The original Freeview medium is terrestrial and not receivable with a satellite receiver as it requires a COFDM tuner - not QPSK as is used for digital satellite.
    It also uses totally different frequency ranges (UHF about 480-830 MHz rather than the 10700-12700 MHz used for satellite).
    So the 2 are totally incompatible at the RF level or physical layer.
    You ca buy a Freeview box for connection to your existing TV aerial for around 30-40 quid these days.
    Chris Muriel, Manchester
