Can I used my Ipod Nano as external HD for Philips 5960?
bu5ter
no reason why not but you will have to enable disck use inside itunes for it to show up as a removable drive
chris57
I dont think you can.
The only ipods that ive heard work via USB are the 3rd and 4th generation. The 5th dont work so as thats a leter revision and the nano came out after i would put my money on no.
bu5ter
my 5.5g video one works with other usb dvd players fine with disk use enabled havent got a philips to try it on but dont seee why it wouldnt
