Can I use Xbox live via ICS
Discussion in 'Xbox Forums' started by hi_robb, Sep 14, 2003.
  1. hi_robb
    hi_robb
    Lo folks,
    Just curious on this one.
    I have ADSL (512MB), a USB ADSL modem, and a 10/100 LAN card in my PC. I woudln't mind playing on xbox live, however I don't really fancy shelling out a fair bit on a dedicated router for the purpose.
    Would xbox live work if I plugged in my xbox into the NIC on the PC then used NAT or ICS?
    the PC is of a decent spec to do NAT etc not that I think that matters too much.
    Davey
    Stuff
    PC
    P4 2.8Gig (533mhz bus)
    512MB Corsair Low Latency Platinum DDR 400
    120Gig ATA/133
    128MB Hercules Prophet (Radeon Pro 9800)
    Sony DVD Writer / Re-writer
    Sb Audigy
    15' Sony TFT
    Consoles
    Xbox
    Ps2
    Gameboy Advance SP
    TV
    Sony KD32NX200
    DvD + Sound
    DavS550 (Soon to upgrade speakers to KEF eggs)
  2. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    Yes This is one of the options that xbox give you to connect
    the only prob is you need your pc to be on at all times to allow the link also there is a piece of sofware you may need to down load to make this work
    Personally I would go for the router option I paid £50 max for my router off ebay now you can be contantly connected using a cat lead you can now get these very cheaply now on Ebay for as little as £20. The ADSL router modem i have is called ETEC usb/10/100
    easy to install
    Also I have been told that the PC link can Make the link slower
    causing lag in the game witch is a bit of a pain
    try the links below should explain all
    http://www.xbox.com/en-GB/live/start/connect/sharedpc/
  3. mr chadwick
    mr chadwick
    ive used ics since day one and have had no probs at all.
  4. hi_robb
    hi_robb
    Ta chaps / lasses.
    Dave
