Can I use Voip to record my conversations?
Discussion in 'General Tech & Gadget Forums' started by alexb123, Aug 6, 2005.
  1. alexb123
    alexb123
    Aug 6, 2005
    57
    Does anyone know?
    Many Thanks
  2. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    35,647
    5
    16
    CyberSpace
    +10,413
    Yes, but that depends very much on what software you use...
    My experience at the non-enterprise level of the market is mainly using Asterisk as the PBX. I don't tend to use softphones around the house as I prefer a normal hardware phone and not having to have my PC running all the time....
    With Asterisk you can 'easily' program buttons on your phone that will initiate the recording....
    But as you have to ask, Asterisk maybe a bit too much.....
    If you don't mind having to be near your PC, or you maybe using your pc for VOIP anyway....There are loads of applications out there that can record whatever your soundcard is playing...Mainly made to circumvent DRM and netcasts, but easily applied to record a VOIP phonecall....
  3. Dr Diversity
    Dr Diversity
    Use Musicmatch to record through your soundcard. Get v6 from the old software site because this version records the sound card without needing to pay (as in later versions)
