Can i use this lead for my pan ae100
Discussion in 'Projectors, Screens & Video Processors' started by dsm12475@yahoo., Mar 31, 2003.
  1. dsm12475@yahoo.
    dsm12475@yahoo.
    Mar 31, 2003
    13
    I have a panasonic ae100 pj and a graphics card that has dvi input on it,can i buy a dvi to vga lead and plug the dvi in the graphic card and the other vga end to the pj,if i can will this allow me to have both my pj and comp monitor showing pic at same time.thx for help..............
  2. Pulsar
    Pulsar
    Jan 19, 2003
    3,136
    West Midlands - Stourbridge
    +330
    Not sure about that, but DVI to VGA converters can be purchased for a few quid and will do what you want, give you 2 VGA outputs. They usualy throw them in with the graphics card, it may be worth checking your box.
    Rob
  3. Kramer
    Kramer
    Yes, a DVI to VGA "dongle" will basically give 2 VGA outputs from your graphics card.
    The DVI/VGA connector/adapter will only allow a VGA signal to your AE100 though (good job as the AE100 hasn't got DVI capability!)
    2 monitors is fine. Works well. Loads more info in HCPCs about dual monitor use, try a search there.
    :smashin:
