Can I use this Digibox???
craigfin
I found my old Amstrad DRX400 digibox upstairs where its been hidden for a few years after having Sky + fitted.
Can I use this box at all to get Freeview in my bedroom?
I don't want to link with my existing system at all as the dish is on the other end of the house and I don't want to run miles of cable and drill more holes. I just want a stand-alone Freeview system without a multiroom subscription.
Can it be done? Will the box recieve a digital signal through the RF input or does it have to be Dish input connection only?
Will I need a indoor digital aerial as I have an indoor TV aerial which I think is standard? I ask this question as I can get digital Freeview through this aerial into my Archos AV700TV so it must be capable of receiving digital signals.
Will I need a card at all for either of the slots?
I apologise if the questions are a bit noddy but I am fine with Sky + but know very little about Freeview / FTA systems.
Any help appreciated.
Craig.
Chris Muriel
You cannot use a satellite receiver (like your DRX400) with a terrestrial aerial ; it has to be connected to a dish and LNBF ; the LNBF is powered by 14/18 volts that the satellite receiver provides at its LNB socket.
Freeview uses DVB-T transmissions in the 460-850 MHz band with COFDM modulation.
Sky satellite uses DVB-S transmissions with QPSK modulation in the 10- 12 GHz region.
So the 2 are totally incompatible.
Chris Muriel, Manchester
hornydragon
to us ethe box it needs connecing to a dish either a new one or existing and without a card you will get most channels with a £20 fTV card you wll get all the channels you can without a sub (not the same channels as Freeview tho broadly similar but not the same)
Graham_E
Is that a "no" then?
Chris Muriel
Incompatible = no.
but some people like it when I talk dirty :D
Can't help it as I spend much of time answering technical or applications questions from designers using our ICs ( but I get well paid for being an anorak).
Similar threads
The Best Netflix Movies and TV Shows Coming in October 2020. Tom's Thumbs.
