Can I use this cable...?
Discussion in 'Cables & Switches' started by chalkstorm, Mar 17, 2006.
  1. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Hi all
    I have just picked up a Monster Component to Component. I actually use HDMI - but could I use the cable as a sub interconnect? Would it be better than the cheap think I am currently using?
    Thanks in advance
    Si
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    Yes - I used to use £8 Digital ICs for my subs low level connections from amp, worked perfectly well. Component cables are no different from coaxial digital cables or anlg ICs IMHO when used in an audio sense.
  3. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Great, thanks for that!
    Si
