Can i use the vga and s-video output on a ati at the same time?
Discussion in 'Desktop & Laptop Computers Forum' started by schillaci0, Jul 7, 2005.
  1. schillaci0
    schillaci0
    Jan 18, 2005
    670
    Starting to get where I want to be
    +14
    :hiya: I have a pundit R with ati 9200 integrated graphics card and i want to be able to run the s-video and the vga outputs at the same time, does anyone know if this is possible.
  2. DaveP
    DaveP
    Yes, it is easy to do.
    Dave
  3. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    :hiya: Dave,
    thaanks for the reply but how is it done? :lease:
    Simon
  4. DaveP
    DaveP
    Make sure you have both connected. Go into CCC (Catalyst Control Centre) and IIRC there is a Displays wizard. If you haven't got CCC then you can just enable it from the settings menu from Display Properties. (Right Click Desktop, select Properties)
    Dave
  5. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    Hello dave
    I have tried what you said (i think) but am not able to have them on simultainesly only one or the other not sure i am doing it correctly.
    simon
