Can i use the £2 Splash voucher more than once?
Discussion in 'Shopping, Deals, Discounts & Bargains' started by Herbal, Jan 18, 2004.
  1. Herbal
    Herbal
    Ok can i use that £2 voucher (one per email) more than once?
    Has anyone done this?
  2. Herbal
    Herbal
    50 views and no replys?
    Has ayone done this
  3. deanjamin
    deanjamin
    Sep 11, 2003
    102
    19
    Nottingham
    I don't think you can use the same voucher more than once, but you can keep getting more vouchers and using them with the same credit card number/email address.
  4. Herbal
    Herbal
    So if i click the Voucher access page, and get a new code
    Will give it a go thanks
  5. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    You'll need to clear out your cookies tho.
  6. Herbal
    Herbal
    Ok, why whoud i need to clear my cookies?
    I have just done about 10 codes, using the same emails i had with the cdwow trustcard
    Will they get there, or because i havent cleared my cookies. will not.
    Can anyone confirm also, they have had numerous orders with them using this voucher code?
  7. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Sorry, my mistake. Getting voucher confusion :blush:
    Some you need to clear cookies some you dont :)
