Can I use surrounds as front speakers?
Discussion in 'Home Cinema Speakers' started by Garbage_Guy, Aug 23, 2003.
  1. Garbage_Guy
    Garbage_Guy
    Hi guys, first post.so be gentle......
    My wife has moved the front room around and has now put the 32" tv in a corner!!! So my Polk RT8's floorstanders wont fit :(
    I was thinking of using the Mission DS77's as front and the Polk's as rears and buying a sub to make up the difference in bass.
    I also have a CS250 Polk centre speaker.
    Will this work?
    Or cos' the Missions are 2 way Bi-polar does that complicate things?
  2. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
    No. Bi-pole speakers as mains is the worst sounding idea I've heard in a while. Yeuck. Steer well clear!
    Only thing you could try is a sub-sat speaker package, either that or ignore the wife?:D
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    In my opinion, it will sound awful. Just got some 77Ds to diffuse my rear sound field, and they really complete the surround effect, so in my opinion, totally inappropriate for front duties. Especially if you listen to stereo music on the system too.
    If i were you i'd get a new wife, but then again, i'm only 21, so i guess she could have her benefits, i don't know. :D
  4. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
    Failing that, sell your wife, buy a set of Gallos and decent sub?;)
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Why not connect up your bipole rear speakers at the front together with mismatched centre and watch a film with it like that. Unless Mrs Garbage_Guy has cloth ears she will dislike the sound and change the room back again
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Shame on you Smurfin for suggesting that his wife is worth less than two stars :D
  7. Garbage_Guy
    Garbage_Guy
    Cheers lads, she did suggest buying a sub/sat package, but I was just trying to save a few pennies.
    I think I'll try to keep the Polk RT8's as rears as they have a very powerfull bass.
    I was reading in another thread that the new MJ Accoustics 100 sub gets good reviews which satelites would go well with it?
    Sony STR DB930 Amp
  8. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
    Now now Ian:nono: ;)
