Can i use sky box without sky dish?
Discussion in 'Sky Digital TV Forum' started by geordieboy25, Aug 24, 2013.
  1. geordieboy25
    geordieboy25
    Feb 2, 2008
    1,519
    48
    Newcastle
    +42
    Hello all.
    I'm in the process of a house move and i have sky at my current address via a Sky + HD box.
    As the box is my property i would like to hook this up in my new house without a sky package.
    Can i get freeview through this if i plug it into a normal freeview ariel or does it need to be connected to a sky dish for it to work?
    Many thanks
  2. Sonic67
    Sonic67
    Sep 14, 2006
    44,567
    11
    167
    Home
    +22,895
    ? Freeview is throgh a TV aerial to your TV or through a Freeview box.
    Freesat is from a dish to a freesat box.
  3. Mark uk
    Mark uk
    Apr 7, 2011
    440
    28
    Derby
    +41
    You need a dish.
  4. 961
    961
    Oct 13, 2006
    4,674
    Berwickshire
    +666
  5. HD sceptic
    HD sceptic
    Apr 1, 2009
    814
    28
    Glasgow
    +81
    Yes, it makes an excellent doorstop! You can also use it as a paper weight!
  6. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Strictly speaking you do not need a dish although you do need a microwave antenna capable of receiving the Ku band. The parabolic dish is the most common design but they are available in many different formats including flat plate, "pipe", rectangular block, hemispherical and spherical.
    It certainly will not work with a Freeview aerial which is for the UHF band.
  7. rogerh
    rogerh
    Jul 4, 2004
    440
    Maidstone
    +10
    Can we have a link to somewhere we can find out more about these "microwave antenna capable of receiving the Ku band" please?
    I'm looking for an alternative to a dish.
  8. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Google Ku band antenna and you will see it is a dish, or now, rarer than hen's teeth, a "squariel"!
  9. rogerh
    rogerh
    Jul 4, 2004
    440
    Maidstone
    +10
    Thanks. That wouldn't solve the problem I have with pigeons on the brackets then anyway.
    It was just a thought.
  10. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,437
    Redditch
    +4,159
  11. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Not true - although a dish is by far the most common there have been numerous different designs of Ku band microwave antenna over the years, including flat plates ( the Squish etc), tubes, lens horns, spherical and hemi-spherical (see farragsat - YouTube ) and even one built into patio chairs. Virtually all of them however require some sort of bracketry if mounted to walls or chimneys or to attach lnbs.
