Can I use Sky+ box for single input only?
Discussion in 'Sky Digital TV Forum' started by Hades, Dec 21, 2006.
  1. Hades
    Hades
    Jan 10, 2002
    11,914
    The Yorkshire Dales
    +1,184
    Hi all...
    My Mum's very old Sky box is on the blink. I have just had HD installed and have my old Sky+ box going spare. Is it possible for me to use this with just a single input? As I would like to take this to my Mum's and connect it up, then ring Sky and pair it up.
    Many thanks in advance,
    Gazza.
  2. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    Yep :thumbsup:
    I'm using one with a singal input - I don't have a Sky subscription so get all the freesat channels.
  3. Hades
    Hades
    Jan 10, 2002
    11,914
    The Yorkshire Dales
    +1,184
    Cheers for that. Will take it round to my mums and sort it out this afternoon. :)
  4. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    I didn't need to ring Sky with mine - I had an old viewing card I hadn't used for about 2 years - put that in and Channel 4 and 5 became available after 10-15 minutes.
  5. w3dal
    w3dal
    Aug 4, 2002
    5,058
    Chelmsford, Essex
    +590
    Your need to ring Sky if you want the sky + functions.
    im running off a single feed and works fine, you can only record the channel your watching but its far better than a normal Sky box.
    Dal
  6. Hades
    Hades
    Jan 10, 2002
    11,914
    The Yorkshire Dales
    +1,184
    Well that was painless. Just swapped it over and all worked fine :)
    Cheers,
    Gazza.
