Can I use recorder instead of player?
Discussion in 'Home Cinema Buying & Building' started by crocket99r, Dec 29, 2006.
  1. crocket99r
    crocket99r
    Oct 18, 2006
    101
    16
    Does anyone know if I can use the Panasonic DMREX75 instead of the standard player with the Panasonic SCHT545W?
    I would like to use the recorder as it's upscaling whereas the standard player isn't, but I am unsure if it will have the same functions that the player.
    I've ordered the SCHT545W but not ordered the recorder yet until I can be sure of compatibility.
    Thanks for your help.
  2. crocket99r
    crocket99r
    Oct 18, 2006
    101
    16
    Anyone help?
