Quantcast
Can I use prog scan?
dynamic turtle
If I connect my dvd to my tv using a component-to-scart cable, will my tv accept the dvd players prog scan image? Does my tv have to be prog scan compliant?
Cheers,
DT
dynamic turtle
Oh well, I thought that might be the case :(
Another question, then: Will I get better picture quality using a component-scart lead as opposed to a scart-scart lead (all other things being equal)?
I know I won't be getting component quality images on my tv but will there be a slight improvement, or will the difference be negligable?
Thanks,
DT
