Can I use phono & digital connections at same time?
Discussion in 'AV Receivers & Amplifiers' started by fudge, Dec 30, 2004.
  1. fudge
    fudge
    May 20, 2003
    My DVD player and Freeview box both have phono audio outputs. Both also have digital outputs (Freeview co-ax, dvd optical).
    My amp has the same inputs but only the phono activate the auto-switching of devices.
    To use the auto-switching I need to connect phono-to-phono but can I also use the digital connections at the same time, to give the best sound output?
    If not will there be a discernable difference in sound quality if I just connect with phonos.
