Can I use my Panasonic NV GX7 to transcode analogue to digital
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Budgie, Jan 27, 2003.
  1. Budgie
    Budgie
    I'm trying to transfer my old (V8) analogue videos, onto my PC so I can edit them. I can record the analogue video on to the Pana DV tape, and then capture it... but this takes twice as long... and I've got a lot of analogue tapes.
    If I try togo "straight thorough" the Pana and capture onto the PC, its all OK until I tell Pinnacle Studio 8 to start capture... at this point the Pana is placed into play (by Studio 8) and I can no longer see the stuff coming in from the analogue camcorder.
    Anyone got any ideas how I can stop Studio controlling the Panasonic while I do these captures?
    Ta
  2. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    Try using a different program to record the DV.
    An obvious contender is DV_IO
    http://www.carr-engineering.com/dvio.htm
    It's a very (and i mean very) simple DV capture tool and should do the job perfectly.
  3. Budgie
    Budgie
    Thanks dnrc ... I'll give it a go, and update this thread if (or should I say when ) it works
