Can I use my Mac with Pronto NG 950????
Discussion in 'Home Cinema Control & Remote Controls' started by princephilly, Jun 2, 2005.
  1. princephilly
    princephilly
    Hi all, Im wondering if anyone could help me?? I have just bought the RU 950 and now want to do some editting on it, is it possible to use the included software on my Mac?? or is there any avalibly software i can buy/download????
    Many Thanks
    Phil
  2. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    You would have to use something like Virtual PC on your MAc and run Windows on that. I tried it a while ago and it seemed ok (though this was a test with a Marantz RC5400). I currently run an MX3000 remote, running through Virtual PC 6 on an iBook G3. To say it runs slow would be a compliment.... but it does indeed work, and connects perfectly through the USB port using Microsoft ActiveSync.
    Give me a shout if you need any more info.
  3. bxd
    bxd
    Oct 17, 2001
    1,482
    Southampton
    +136
  4. princephilly
    princephilly
    excellent thanks ill give that a try!! hopefully it wont be to slow on a g5 mac!!!!
