Can I use my digital camera as a webcam?
Discussion in 'General Chat' started by mcfarfs, May 11, 2005.
  1. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Hi, I have a digital camera (Kodak Easyshare DX4900). Is it poss to use this as a webcam? It does have a video out, which looks like a 3.5mm or maybe 2.5mm socket.
    Is it possible to get a video - USB cable or something? Because my computer does not have a video -input i dont think.
    Cheers (sorry this is the wrong forum)
  2. shodan
    shodan
    Dec 11, 2001
    10,307
    shoeburyness
    +4,681
    Interestng question! Although I've never useda webcam I always presumed they are just USB plug and play? And they are SO cheap now anyway aren't they?
  3. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Yeh i guess they prob are. But im kinda hoping there is a cable sumwhere out there whcih goes from video to usb. i have just realised i have a cable which goes from the video out on my camera to a video phono connector.
    So is tehre a cable to go from that to USB? anybody know?
    I think decent webcams are still quite expensive to be honest, and if i can use my camera itl be decent quality!
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Actually, alternatively, is it possible to buy a video card (do they exist?!) with phono and video input?
    Because if i can get one of them i can put all the home videos on my PC and then to DVD!
  5. shodan
    shodan
    Dec 11, 2001
    10,307
    shoeburyness
    +4,681
    I thought all digital camera's connected via USB and that was it. So if thats the case then it would just be software needed to use it as a webcam...
  6. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Yeh mine does, via a dock. But it also has a mini-usb out and a video out bit on the camera itself.
  7. Astaroth
    Astaroth
    Jun 22, 2004
    2,283
    63
    London
    +117
    Some cameras can be used as a webcam and others cant. Unfortuantly there isnt just a cable that can convert composite video into a usb signal.
    You could get a video capture card and see if this works but I would suspect that it wouldnt due to the fact that (1) the quality is much higher than webcams and I doubt it would process in time (2) all software looking for a webcam feed will look for USB or possibly Firewire and not the composite in of a video capture card.
    As has been said before, given the price of webcams, if your camera doesnt support this out the box then just spend a few quid on a webcam
  8. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Ok cheers!
  9. bmthsteel
    bmthsteel
    Jan 5, 2009
    Unfortunately, i think a lot of the Kodak Range is incompatible with most webcam software.
    Unless you were to use a program that can make a Kodak camera work to be a webcam, and since it has a Video Out port, it would be better to buy a Video Out To USB cord.
  10. Crocodile
    Crocodile
    Nov 4, 2002
    15,527
    +4,718
    You did notice that the thread is 44 months old? ;)
