Can i use my Barco 800 remote for my 801's?
Discussion in 'Projectors, Screens & Video Processors' started by John Watts, Nov 4, 2005.
  1. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Hi folks as the title says,
    My 801's (coming tommorow) has a service remote with it but not a spare one.
    So can i perform the basic functions with my 800 remote or do i need to buy a 801's unit?
    Thanks,
    John.
  2. mrking
    mrking
    Yep, RCU800 works just fine with your new projector.
  3. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Perfect.
    Thanks. :thumbsup:
  4. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    John,
    You asked me for a Barco remote, looking here it looks like you had one already....
    It should work?
    Why do you need another?
    If it does not work check the remote ID is the same as the projector, thats the usual error.
    Or did you just want the newer looking ones?
    You are right they are expensive just to turn the pj on/off - BUT when doing convergence they are a god send...
