Can i use Mission M73 Floorstanders as rear speakers?
D
dangermouse
Richer Sounds are sell Mission M73 Floorstanders for £95 a pair and was think of buying 2 pairs (front and rear) and a Mission M7C1 Centre Speaker.
Will it be ok to use these as rear speakers or will the balance be all wrong.
Ian J
Matching rear speakers are great for surround sound and are what the purists recommend.
Nobber22
I have M73's as fronts, but I recommend the M7C2 centre speaker. I prefer it to my old M7C1.
B
bob007
Ideally the surrounds should be anything between 60cm/90cm above ear height when sat in the listening position, being as they are floorstander I would see how they sound at floor level first before you nail them to the wall with 6inch rawbolts. :D
micb3rd
I second the movement towards a M7c2 it is a much better match to the M73's.
D
dangermouse
Thanks people
I think i will go for the definatley better center speaker.
But i dont to be drilling holes in the wall or buying tall stands for the rears, thats one of the reasons i was going for the floorstanders.
Reiner
I also tend to agree that rear speakers on ear level are less then ideal unless they have quite a distance to the seating position. But if it's not possible otherwise than you can of course compromise by using floorstanders ...
