can I use Bose cubes with a std amp
Discussion in 'Home Cinema Speakers' started by Mr Bimmer, Jan 7, 2004.
  1. Mr Bimmer
    Mr Bimmer
    Dec 27, 2003
    90
    Essex
    Is it possible to use a pair of Bose double cubes as a rear chanel by wiring in a passive crossover? I really need some small rear speakers, and they must be white.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yes but will require the bass unit as that is the crossover without that then you have tweeters that will be bolwn up!
    Am3 and AM5 will work or try gallo micros available in white
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The Bose cubes don't have tweeters.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. Mr Bimmer
    Mr Bimmer
    Dec 27, 2003
    90
    Essex
    What are Gallo like? I know they look good, which is important in my room, but how will they sound. My room is 29' X 13' with wooden floor, and painted walls. I am using Def Tech Mythos fronts and centre, with a BK XLS200 sub on it's way.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Gallos would be ok is it for 5.1 movies or DVD-a SACD as well?
  7. Mr Bimmer
    Mr Bimmer
    Dec 27, 2003
    90
    Essex
    Mainly music with about 15% movies. Style is important, Thats why I haven't gone for the M&K5s.
  8. Mr Bimmer
    Mr Bimmer
    Dec 27, 2003
    90
    Essex
    By the way, the amp is a Pioneer AX5i
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Stereo music?
    its going to possibly sound a bit odd what ever you choose if you can hide the bass module then BOSE am5 will be very unobtrusive they do lack midrange not sure how important that would be with your other speakers though
  10. z5461313
    z5461313
    Sep 18, 2001
    1,630
    +235
    Could you try connecting the 2 Bose speakers as 'Small' type to the amplifier
    Then all bass will go to the sub-woofer
    By they way I think the dual cubes sound better than the single cubes
  11. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,379
    Somewhere in South Yorkshire
    +5,765
    This is my main criticism of Bose. You should not drive their satellites directly; only via the 'Acoustimass' module. Drive them directly and you run the real risk of killing them.
    Take a look at Energy Take 5 (or 5.2) as an alternative, very compact (and nice sounding IMO) alternative for your satellites.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If you built or bought a dedicated crossover/filter that work at the correct frequency then it would be fine, but thats a lot of messing around.
  13. Mr Bimmer
    Mr Bimmer
    Dec 27, 2003
    90
    Essex
    Thanks Guys. I will look into the crossover route.
