scoooby
OK, So Blue-Tac probably won't hold the weight of a mighty 42 incher... but I wish there was an easy solution to the problem of wall mounting a plasma screen...
I live in a timber frame building and intend to mount the screen on an external wall- the make up of the wall, is plasterboard on a timber frame.
I was planning to chop out a bracket sized piece of plasterboard, replace with a 'same-size' piece of ply or MDF, fixed to the timber studs, and then fix the bracket to that... is this the best was to mount a screen on a timber stud wall?? I'm sure this has been discussed in previous threads- although I couldn't find any that relate directly.
Any comments?
I just couldn't possibly spend several grand on a telly and put it on a stand.. it's wall or bust.. just how to do it with minimum cost! I wouldn't mind paying an expert to do it for me, anyone know someone who doesn't charge a fortune? Anyone used the Curry's £299 wall mount service?
Please help.. I'm losing sleep on this.
Any comments?
