can I use an Ixus from the US in the UK?
Discussion in 'Photography Forums' started by Elvis, Jan 27, 2004.
  1. Elvis
    Elvis
    If I buy a canon Ixus (Elph in the US) in the US will it work ok in the UK? Am I likely to have any problems with it? Has anybody done this?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
    Possible problems:
    1) Mains voltage of the battery recharger. If it is rated at (up to) 230/240 V then OK. If it is rated at only 110V then you'll kill it when you plug it in.
    2) If this camera has a TV output, it may be configured to only supply an NTSC signal. Which may or may not work with a given UK TV. If it has a choice of PAL or NTSC as UK models do - then OK.
    Otherwise - no forseen problems.
  3. Elvis
    Elvis
    Thanks for the response.
    I've checked canon's US website and the Digital Elph s400 outputs to both PAL and NTSC as with the UK version. It also has the same battery (NB-1L) so I'm guessing I could use a UK recharger with it. I already have one of these from my ageing Ixus1. As far as I can see it's the same (rebadged) camera with a different recharger to account for voltage variations.
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Most chargers seem to be multi-voltage, you might be pleasantly surprised. I use one from Japan (more or less the same electricity as USA) without any problems.
  5. mre15
    mre15
    Mar 15, 2003
    635
    28
    Gloucester
    +36
    you will have no problems at all, the charger is a universal 100-240 v unit and the output pal or ntsc is selectable.
    The only problem you will have is if you get a fault as canon uk will not honour the warranty at all.
    Also dont expect a mega bargain, you can get them here for less than 300 quid now.
  6. Elvis
    Elvis
    I suppose the warranty is a bit of a worry, the cost (at current exchange rates) for the camera is about £217 in the US as opposed to £299 in the UK. Is the warranty worth £80?
  7. mre15
    mre15
    Mar 15, 2003
    635
    28
    Gloucester
    +36
    dont forget in the us you need to add sales taxes on top of the price make its even closer to the uk price
  8. Elvis
    Elvis
    Good point, I had forgotten that. NY sales tax is 8.6%, which takes the cost up to £235, now it's only £63 cheaper :(
  9. LV426
    LV426
    Jul 14, 2000
    13,425
    +5,824
    Plus (technically) you declare it to HM C&E when you arrive here, and they add duty and VAT. (Reckon about 25%).
