Question Can I use an Amazon fire stick straight into a projector?
Discussion in 'Home Cinema Buying & Building' started by samannwhat, Jul 3, 2015.
  1. samannwhat
    samannwhat
    Jun 7, 2013
    4
    hi, I'm assuming that I can just plug a firestick in the spare HDMI port on the back of our projector (it has 3 HDMI ports) rather than having to run it through the blu-ray player? We currently watch all our tv through a Panasonic blu-ray HDD and while I player and Netflix work quite well it would be handy to have access to Amazon prime and some of the other on demand channels.
    Sorry, this is probably a really obvious question...
    Sam
  2. dr no
    dr no
    Mar 30, 2004
    12,953
    +7,398
    I see no reason why you cannot. Assuming it can be powered by its normal route
  3. xar
    xar
    Jan 31, 2013
    1,753
    116
    Edinburgh
    +1,037
    Should work for image, but problem would be getting any sound. With the image going direct to the projector there would be nothing to receive a sound signal
  4. Kev Greenhalgh
    Kev Greenhalgh
    May 3, 2012
    588
    5
    25
    96
    Manchester
    +741
    What?
  5. dr no
    dr no
    Mar 30, 2004
    12,953
    +7,398
    I meant that the stick will need to have a power supply (USB or plug?)
    But as poster above has said sound may be a problem too.
  6. Kev Greenhalgh
    Kev Greenhalgh
    May 3, 2012
    588
    5
    25
    96
    Manchester
    +741
    Gotcha. :)
  7. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Does the projector have Audio Out, do you have an AVR in the room with the projector
  8. Jmdnnlln
    Jmdnnlln
    Mar 17, 2008
    16
    Lancashire
    +3
    Hi, the answer is definatley yes.
    I run a firestick with Kodi loaded, it's actually plugged into my Panasonic surround sound system which in turn continues into my Optoma projector.
    Kodi allows me to stream my movies from a Seagate 3tb nas centre without effort. And allows me to stream the latest movies directly from the net.
    I have also plugged the firestick directly into the projector and it works brilliantly...just no sound.
  9. Hdavies347
    Hdavies347
    Sep 30, 2016
    Northampton
    Hi. So what would I need to buy, aside from a HD projector and projector screen to run firestick (kodi enabled) through the projector?
  10. Roohster
    Roohster
    Jul 1, 2004
    4,707
    7
    Derbyshire
    +5,797
    Could you give a few more details about your setup?
    What are you using for sound?
    Plugging the firestick into the projector will mean you'd only get sound from the projector's built in speaker (assuming it has one).
    Ideally you'd use the firestick plugged into an HDMI input on an amp/receiver for decent sound.
    Plugging one into a TV works because most TVs have amplification and speakers.
  11. Jmdnnlln
    Jmdnnlln
    Mar 17, 2008
    16
    Lancashire
    +3
    Hi all I know I haven been here for a while and a question was asked..sorry.. been busy. My setup is now a optoma w307ust DLP 3D Projector, Which is plugged into a Panasonic SC-HTB20. The amazon fire stick is plugged into the Panasonic which produces a fantastic sound.
  12. karlp606
    karlp606
    Feb 19, 2009
    4,493
    71
    Hull E Yorks
    +76
    Hi there Im currently in the same predicament as you, Im purchasing a optoma pj with hdmi input for ps4, sky etc then going to run audio direct from them into my sound set up, but how do you run your firestick through a HDMI in your soundbar? As previously posted if I plug my firestick into the projector I will get no sound as I dont have a audio out on the pj.
  13. Roohster
    Roohster
    Jul 1, 2004
    4,707
    7
    Derbyshire
    +5,797
    I can't think of a simple way to do it with a soundbar, obviously it's easier with a receiver.
    You need something that can switch between sources, so some kind of HDMI switcher.
    Then you need to feed the output of the switcher to both the projector and the sound bar, so you need two HDMI outputs.
    Perhaps something like this?
    Neet® HDMI TRUE MATRIX - 4K 4 Input 2 Output Switch: Amazon.co.uk: Electronics
    Obviously do your research first to find out if it will work, but that one gets great reviews.
  14. karlp606
    karlp606
    Feb 19, 2009
    4,493
    71
    Hull E Yorks
    +76
    Think I'm going to head down the av receiver route, would be the easier to plug all my inputs (firestick PS4 etc) into the av via hdmi then run a hdmi out the av to projector?
  15. Roohster
    Roohster
    Jul 1, 2004
    4,707
    7
    Derbyshire
    +5,797
    Yes, definitely the way to do it.
    Audio and video will be switched together, so it's simpler... and better because the video and audio won't have to pass through multiple devices on their way to the projector and receiver, just the one.
