Can I use an 85W magsafe charger on the 13" MBP?
Peridot
Anyone know whether the it's okay to use the 85W magsafe charger intended for the 15/17" models on the 13" one?
TIA :)
daroca
TIA :)
Yes it will work fine... the 13" Macbook will draw the power it needs, which is less that the larger laptops.
D
Deleted member 27989
Does anyone know if the other way round is also ok if not using at the time
it is, but you can't use it on a MBP when the battery is fully down as I noticed and at low battery using the DVD is also a no no....
But for topping up, I generally use my wife's power adapter who keeps it downstairs....
jezzery
Thanks, will use my mates charger at work now when I see it lying around to top up :thumbsup:
