Can I use a switch with a homeplug to get 2 outputs?
Keiron
As title really - can I take a cable from a homeplug to a switcher, then 2 cables from the switcher (one to my media player, the other to the TV for iPlayer etc)? Will it work? Or do I need 2 homeplugs? Or alternatively, can I get a simple splitter to take 2 cables from the homeplug?
Keiron
Thanks - I acted in haste last week and bought a TP Link pair of homeplugs with single ethernet outlets. Works brilliantly (my wirelessly streamed video to my media player was previously stuttering). However, I need an output to my media player and my TV.
Could I use a simple ethernet splitter, the sort of thing you can get on ebay for 99p? Or would that half the bandwidth (if that's the correct term, and if it's something I need to worry about).
leecavturbo
It needs to be a switch or hub.
A cable divider/splice is crude to say the least and would only serve to work with only 1 item powered at a time
beerhunter
I would use a switch instead.
BTW, contrary to the previous post, you can have two devices working at once with splitters. They way they work is you put one on each end of the cable and they "split" the four pairs into 2 X two pairs. So they only work with 10/100 Base-T Ethernet and by the time you buy a pair of them, you may as well do is properly with a cheap switch. Especially if you wish to move to 1000 Base-T in the future. (It needs all four pairs.)
Keiron
Thanks...although I'm not sure what you mean by "four pairs"?
However, an additional homeplug (£17ish) is about the same prices as a switch, and a neater solution!
mickevh
There are 8 wires inside a UTP cable, grouped into 4 pairs of 2.
Of those 4 pairs, 100mbps ethernet "only" uses 2 pairs whereas 1000mbps (Gigabit) ethenet needs all of them.
beerhunter
A 10/100 Ethernet Switch is actually less that half that and "switching" is more efficient than having an extra device on the "shared medium" Local Area Network that is your mains wiring.
So I would submit that a switch is a more "elegant" solution.
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
