alberich99
Hi all,
I would like to know if my Klipsch Quintet III speakers are a good match for a Sony STRDH750 receiver. Below are the specs for each.
Thanks!!
Receiver Specs:
FREQUENCY RESPONSE: Satellite: 120Hz-23kHz
Center: 125Hz-23kHz
SENSITIVITY: Satellite: [email protected] volts/1 meter
Center: [email protected] volts/1 meter
POWER HANDLING: Satellite: 50 watts (200 watts peak)
Center: 75 watts (300 watts peak)
NOMINAL IMPEDANCE: 8 ohms compatible
TWEETER: One .75" (1.9 cm) neodymium magnet compression driver
HIGH FREQUENCY HORN: 90(d) x 40(d) Tractrix Horn
Thanks!!
Receiver Specs:
- 7.2 Ch. 1015W A/V Receiver (145W x 7 at 6 ohms, 1kHz, THD 0.9%)
- Speaker Impedance:6-16 Ohms
- Speaker Selector:A / B / A+B / Off
- Sub Woofer X' Over:17 points (40 - 200 Hz)
- (6Ohms, 1kHz, 1ch driven) THD:0.9%
- (6Ohms, 1kHz, 2ch driven) THD:1%
- 6Ohms, 1kHz, 1ch driven:145 W
- 6Ohms, 1kHz, 2ch driven:105 W + 105 W
- 6ohms, 20-20kHz, 2ch driven:90 W + 90 W / (0.09%)
- Band:6
Center: 125Hz-23kHz
