Can I use a single source for multiple amps?
Tomodan
A title says, I would like to run a single source (an Apple airport express) into several separate amps (they will all be Cambridge Audio A1) in order to set up a cheap multi-room system. I need separate amps as I want to be able to control the volume in each room separately and have the option of using other sources if required Can I do this? I was thinking of simply building a 1 into 4 RCA splitter.
My concern is will there be any issues with noise or feedback by doing this?
I know an option would be a speaker splitter box but I would then loose the ability to have separate sources in each room
Anyone who has tried this your advice would be appreciated!
