Question Can I use a projector with just a Freeview box ( no tv )
Discussion in 'Home Cinema Building DIY' started by Jaffa1978, May 26, 2019.
  1. Jaffa1978
    Jaffa1978
    May 26, 2019
    Kirkcaldy
    Might sound like a silly question but can I buy projector & connect it to a Freeview box via cable without the need for a tv? If so could you recommend a projector for under £100 thanks for your help
  2. Nayfne
    Nayfne
    Feb 3, 2013
    4,817
    5
    3
    north east
    +11,639
    Do you mean plug the TV aerial into the freeview box, and then HDMI from freeview box? Then yes you can, however, not all projectors have built in speakers, so.you would need some form of external speakers etc for sound.
  3. gibbsy
    gibbsy
    May 17, 2007
    14,013
    3
    Cwm Cynon, De Cymru
    +7,869
    If your PJ doesn't have speaker facilities then the box can be connected by HDMI to a receiver, with pass through facilities, or a stereo amp that has it's own inbuilt DAC by digital optical to facilitate sound from external speakers.
