Can I use 2 identical wireless headphones for one TV ?
slaverty
I have an attic conversion and have a tv installed. As there is no door to it I need to keep the guests quiet ! So considering a wireless headphone option. However I usually have 2 guests. If I buy 2 identical systems from eg Argos do you think both headphones will work off one transmitter? I know nothing about this field at all so punting it up for you gurus here. Also if there is more than one technology available what would be the best type to ensure I don't pick up taxi drivers !
PS After a bit of googling I considered a sennheiser IS300-V4 system but its way too pricey.
All comments appreciated.
Steve
Papua
Yes, providing you buy the same type they will both pick up the same singles. Some allow you to change channels so just select the same channel on both and you can listen away.
