Can I take my Sky q box on holiday?
Discussion in 'Sky Digital TV Forum' started by G-Man72, Aug 21, 2018.
  1. G-Man72
    G-Man72
    Feb 16, 2006
    346
    4
    2
    Cannock
    +36
    We are going to Cumbria soon and I was wondering if I could take the box with me and watch the programs we have stored on the box?
    There will be no dish I can plug into and no phoneline so I know it wont record any extra programs however we will have WIFI.
    Thanks in advance.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,367
    Lanarkshire
    +2,514
    Remove the downleads and try playing from the planner.
  3. tom 2000
    tom 2000
    Mar 21, 2008
    3,972
    Craigavon, Northern Ireland
    +403
    You could experiment at home by unplugging the satellite feed and seeing what functionality you still have.
  4. G-Man72
    G-Man72
    Feb 16, 2006
    346
    4
    2
    Cannock
    +36
    Well........I honestly did not think of that!!
    I feel stupid now!!
    I really need that holiday!
    Thanks guys. I will update this later when I get back from work!
  5. rs101
    rs101
    Feb 24, 2016
    453
    43
    Essex
    +168
    You'll also need to power cycle it after removing the downleads for a representative test. Probably find it won't work though - I seem to recall it's like Sky+HD which needs a satellite connection for the initial authorisation.
  6. Jonny76
    Jonny76
    Nov 16, 2014
    556
    43
    Staffs
    +133
    Did this work in the end?..
  7. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,251
    Poole
    +9,556
    Correct so people can't use expired cards.
  8. adam-burnley
    adam-burnley
    Jun 17, 2007
    4,421
    Burnley
    +2,249
    It won't work as it polls the satellite connection on a regular basis to sync the subscription. No connection will block playback.
    You could use Sky Go or download to a compatible device with the Sky Q app instead though.
