Can I switch RGB video using Amp's component video switching (+ composite)?
Discussion in 'AV Receivers & Amplifiers' started by RoughRider, Jul 9, 2004.
  1. RoughRider
    RoughRider
    May 17, 2004
    200
    Wimbledon
    +3
    I have two RGB sources (Sky, DVD).
    My amp (Yamaha A1) has component video switching for two sources, as well as S-VHS and composite. RGB looks better to me than S-VHS and I like using the switching.
    As the amp also switches composite and has an extra composite "monitor out" can I route my RGB signals through the component sockets?
    I would then run RGB (from the component out sockets) + Sync (from monitor out) 4 x RCA to SCART in the television and set it to receive RGB.
    I am concerned because the routing hardware is designed for component i.e. Y (1vp-p/75 ohms) and Pb/Cb and Pr/Cr (0.7vp-p/75 ohms) and I don't know what an RGB signal is and don't want to damage the amp trying this out.
  2. ailean
    ailean
    Hmmm sure you have an A1 and not an AX1 or AZ1? No component sockets on my old A1. ;)
    What I'm trying at the moment is using a RGB->Component converter into an amp and then a Component->RGB converter into the TV. However you loose the WideScreen switching which is on scart pin 8 I think. :(
    When changing channels between 4:3 and 16:9 stuff this is fairly annouying as you have to manually change the aspect on the TV remote all the time.
    So if you're just using a TV you may be better off with remote controlled scart switch and program the remote into your main one.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Yes if the amp can switch the composite to the same source as the component input - and given it's an AX or AZ1, the A1 does not have component sockets as ailean already pointed out.
  4. RoughRider
    RoughRider
    May 17, 2004
    200
    Wimbledon
    +3
    Thanks. I am impressed you can work out what amp I own when I clearly don't know! Must be an AX1 I reckon, not new enough to have a "Z" in it. Looking forward to easy switching :)
