SkyCaptain
Established Member
Just moved into new flat and got a new sky box with the subscription. Still have my old HD box though and the engineer told me i could use it as a freeview box. Well ive just plugged it into the spare telly in the bedroom and it just seems stuck searching for channels.
How do you set it up? Ive go a normal tv arial going into the arial in and a HDMI cable going into the telly from the sky box. I can see the menu ok, although idont seem to able to navigate anywhere, the only option that seems to work is the select button which sends it off looking for channels to display.
Must be doing something wrong as you see these old boxes flogged off on ebay all the time!
