Can I split a satelite signal ?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Levi-501, Sep 6, 2004.
  1. Levi-501
    Levi-501
    Jul 23, 2004
    43
    Guys,
    I have sky installed at home in the living room.
    As I am sure you are aware you can not record and watch two seperate channels.
    I aquired an additional DigiBox and spliter, which takes the incoming signal from the dish and splits it between the two DigiBoxes, thus enabling me to record one channel whilst watching another.
    However, when I try and watch anything all I get is a blue screen with a thing saying check satelite !
    Does anyone have any ideas, or suggetions ?
    I know you can modify your dish to give two output, but this is £200 whereas the splitter is £5 !
    Thanx
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    republic of ireland now
    +62
    u cannot do what u are trying to do so give up. To run 2 boxes u will need a dual lnb and 2 cables from the dish, a separate cable to each box. it will not cost anywhere near 200 quid. if u have a sky dish it is difficult to get a dual lnb these days as sky + REQUIRES a quad lnb and that is about £69.00. Get the quad and u are future proof.
    gb--
  3. BaggieBoy
    BaggieBoy
    May 3, 2004
    38
    The reason you cannot split the cable is that the digibox controls the LNB. It changes the DC voltage to change polarity and it uses a 22KHz signal to change band. If you try to connect two digiboxes that will be trying to do different things with the LNB and unpredictable things will happen.
    Quad LNBs are quite cheap (£40 or so), take about 10 minutes to fix. All you would need to do is run an extra length of cable from the dish.
  4. Levi-501
    Levi-501
    Jul 23, 2004
    43
    Thanx
    BaggiBoy
    Have you done this ?
  5. BaggieBoy
    BaggieBoy
    May 3, 2004
    38
    Yes I changed by original single LNB for a Quad and run three digiboxes without problems.
  6. uczmeg
    uczmeg
    May 18, 2003
    3,433
    71
    Nottingham
    +52
  7. applevenus
    applevenus
    You will need a Quad LNB to start with. I have an active splitter that takes the 4 outputs from this LNB and sends it to 10 outputs. In theory I could drive 5 Sky+ boxes off this. Obviously I don't (!). At the moment I've got a Sky+ box, a mirror sub and 2 FTA-card-boxes running from this setup. This Triax device I have will also take an input from UHF/VHF and I used to have cableTV running through the system also - nowadays it has Ch4 from one of my FTA digiboxes piped around the house (Ch4 isn't available on Sky in Ireland).
    What you're looking to do can be done but you need to add some hardware
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Erm to run one of these dont you need a Quattro LNB not a Quad..... They are different Quad gives 4 full 4 feeds Quattro gives 4 seperate feeds that can be combined to give upto 10 outputs or more!!!! for this you require a thingy... (forgot name) soryy :blush: Its a multiswitch thingy anyway and not really relavent
  9. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    To avoid running additional cables you can combine two signals on one cable (assuming acble is of reasonable quality) with stacker / destacker. Not cheap around £100, but can save alot of bother when trying to rnu another cable.
    Rgds Steve.
