Can I share HD15 socket..
Discussion in 'Projectors, Screens & Video Processors' started by museumsteve, Dec 28, 2001.
  1. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    On my projector I use the HD15 (vga style) socket to input Component from my amp..it's set-up through the menu of the projector..
    Now if I wanted to also use a PC through the projector aswell, could I route the VGA cable and HD15 plug (from amp) into a data switch (vga pinned) then one vga cable into projector and switch between them (whilst powered off of course)..
    I know I'd have to change the setting in the projectors menu each time but wondering if I can run a component through a VGA data swtich box..I assume a data switch box is all pins connected so it shouldn't matter..
    Some expert advice or even just opinions would be greatly received..
    Steve
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    That should work.
    I don't see why you should have to switch the PJ off between switching but there is no harm in being cautious.
    Mechanical VGA switchers are not renown for their bandwidth. but they are so cheap that this has to be worth a go.
  3. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    thanks mate...
    worth a go then..
    I'll see if I can pick one up tomorrow and give it a go..
    I'll let you know..
  4. Neil Bradley
    Neil Bradley
    Go to www.keyzone.co.uk, they ahve a whole host of data switchers available for this sort of Application.
